2006 Pontiac GTO
CHANCE
No longer a Buick guy!!!!!!!!!!!!!
2006 Pontiac GTO Cyclone Gray Metallic W automatic
85,554 miles
Body:
Carbon Fiber Maverick Man spoiler
Carbon Fiber Maverick Man Rear Exhaust Insert w/GTO
Carbon Fiber Maverick Man Splitter
Carbon Fiber Maverick Man License plate frame
Maverick Man Billet Fire Extinguisher Seat Bracket Specifically for the Pontiac GTO With HalGuard Fire Extinguisher
Maverick Man front and rear billet Pontiac Arrow heads
Maverick Man billet front strut cap covers
Maverick Man full Pontiac GTO Billet Beauty Washer Kit
GTOG8TA SAP Grills
Maverick Man Carbon GTO HSV Style Carbon Fiber Honeycomb Inserts for SAP Grilles with billet GTO emblem
Maverick Man Carbon GTO HSV Style Lower Bumper Honeycomb
Pontiac GTO OEM GM Ignition Lock Cylinder Kit not installed
Hendrix Engineering strut bar
Pedders Pontiac GTO Front SportsRyder Struts
Pedders Pontiac GTO Rear SportsRyder Shock
Pedders Pontiac GTO Front Springs
Pedders Pontiac GTO Rear Springs
Pedders Pontiac GTO Urethane Caster Bushing Kit
Pedders Pontiac GTO Urethane Steering Rack Mount Bushing
SuperPro Pontiac GTO Rear Coil Bump Stop
Whiteline Pontiac GTO Rear Spring Pads Bushings
Whiteline Upper Polyurethane Strut Mount Bushings with Bearings
Energy Suspension Pontiac GTO Hyper-flex Master Kit
Hinson Pontiac GTO 2004-2006 Urethane Transmission
Hinson Pontiac GTO (2004-2006) GTO Engine Mount
BMR Pontiac GTO Drag Bags
BMR Pontiac GTO Skid Plate
BMR Pontiac GTO Driveshaft Loop
Hoosier D.O.T. Drag Radial 2 Tire
DBA Pontiac GTO T2-Slot Uni-Directional Rotors
EBC Pontiac GTO Brakes Redstuff Ceramic w/ Low Dust Brake Pad
Russell Pontiac GTO Steel Braided Brake Lines
SJM Line Lock Pontiac GTO.
Custom Blown Goat 6.0 Super Charged fender emblems
Interior:
Bohnman Customs red GTO Interior Illumination Package
JHP voltage and oil pressure dash pod gauges with color and font for 06 gto
JHP extra button for the center console of accessories like exhaust cut outs or line locks
Pioneer touch screen radio
8 inch rear deck sub speaker mounts included
Engine:
6.0 LS2
Magnuson MP112 Supercharger with custom COG 1:1 pulley in back 2.8 pulley up front rebuilt by The High Speed Lab Supercharger Shop plus all bolts replaced with ARP and rotors Thermal Barrier Coated
Soler Performance 95mm Throttle Body
Hendrix Engineering Power Chamber Cold Air Intake not installed yet
E85 sensor
80# Delco Injectors
243 heads ported and polished by High Velocity in Knoxville TN
Accel LS Spark Plug Extreme 9000 Ceramic Wire Sets
ARP head bolts
BTR revised LS2 IN & EX rocker arm with CHE precision trunnion upgrade
LS7 Lifters
FTI custom cam with custom push rods
New timing chain and dampener
New Melling high volume oil pump
Holley LS Aluminum TALL Valve Covers with Brian Tooley Racing Billet Valve Cover Breather with one way check ball
Mighty Mouse Solutions Pontiac GTO Catch Can
ARP Coilpack 12pt Stainess Steel Rust Proof Bolts
ARP Valve cover bolts
ARP timing chain cover bolts
ARP water pump Bolts
ARP starter bolts
ARP Hermonic Balancer bolt
ARP transmission bell housing bolts
ARP header bolts
ARP manifold bolts
ARP fuel rail bolts
Mishimoto Pontiac GTO Performance Aluminum Radiator
Cold Case Pontiac GTO 2005-2006 Silicone Radiator Hose Kit
GTOG8TA Fabricated Aluminum Power Steering Reservoir
ATI Pontiac GTO Super Damper Serpentine Series Harmonic Balancer - OEM Diameter
DeatschWerks Pontiac GTO W300C Series - 340lph Direct Fit In Tank Fuel Pump Kit
Russell Stainless Steel Braided Fuel Line
Exhaust:
JBA shorty headers with JET-HOT classic polish
JBA catless mid pipes
Pypes 2005-2006 GTO X-Box Muffler
Pypes 2005-2006 GTO Pype Bomb Axle Back Exhaust System
Transmission:
RPM Stage 6 4L65E
FTI Performance SRL-3 Series Billet Triple Clutch Torque Converters
Derale Frame Rail Fluid Cooler mounted in front
Derale 4L65E Transmission pan cooler (with a drain plug)
Stock driveshaft with VooDoo chicken Pontiac GTO Red-30a Polyurethane Carrier Bearing installed
Mike aka 2qwk4u built diff with Aussi 3.73 gears and Detroit Truetrac
Harrop diff cover
Tools:
Front and Rear cradle alignment tools
Tech 2 knock off
Mongoose-Plus J2534 OEM Vehicle Interface Cable - GM OEM Reprogramming and Diagnostics
HP Tuners with wide band setup
LS on head Valve spring compressor
LS Fly wheel lock
I'm at work right now but will post picture later
Body is 9/10 only because of rock chips
interior is 9/10 only because of small scratches here and there, but no rips or tears
$25,000 or trade for 86/87 turbo buick
2 ignition keys
2 glove box keys
Factory window sticker
all factory manuals and interactive cd
factory radio comes with it in box
All reactions:
22
2 ignition keys
2 glove box keys
All reactions:
22
GMP CGM 2006 diecast
2006 Dealer brochure
2006 hot wheel
plus odd ball stuff im forgetting
Just trying to help you out on a sale.... I have a buddy that's been looking for one for a while. I'd say you need as many pics as you can post, as you are selling a car for $25k.... with only a handful of pictures........ thanks Mike
Thanks I appreciate it
No problem consider it a bump.....
Are you advertising the car elsewhere?
