212/212 comp roller cam FS
onefastgn
Used for 10k...checked out good from Weber's to reuse. Has slight ware on lobes as expected from use.
$150.00 shipped
I will take it pending close up pics of the ware. Can you catch a finger nail in any of the grooves? Lifters look ok?
I will look at that this evening after I get home from work. Lifters were near perfect and sold already. I don't recall any grooves..Weber is very picky and said it was reusable but showed a little ware on lobes, but I had already decided to go stroker and different cam selection, otherwise I would have reused it.
It's written on the box..slight roller tracks was the ware.comes with thrust button also
PayPal if you want it is: send as friend or add 3%
Tonysturbo@yahoo.com
Payment sent, address should be with it. Thanks
