Iv'e got the supporting parts (as seen in my sig) and i'm running a 221/218 in there right now and the vacume brakes are fine, and the gas milage isn't that bad either. Will it really be that big of a differance going from a 221/218 to a 224/224 ??Yes, we used that cam in our prototype engine w/GN1s and 109 girdle motor.The car ran 134.8 MPH w/25 psi. I would suggest you get your compression to 8.5 or 9:1 .The engine shifts where @ 6000 1-2 & 3 gear and never stopped pulling.The 224-224 also had good street manners but no vacume for brakes I think it would work better with a powermaster brake system.This cam is surely a 9 sec flat tappet, but one thing for sure you won't miss any gas stations.
My compresion is 9.5:1Yes, we used that cam in our prototype engine w/GN1s and 109 girdle motor.The car ran 134.8 MPH w/25 psi. I would suggest you get your compression to 8.5 or 9:1 .The engine shifts where @ 6000 1-2 & 3 gear and never stopped pulling.The 224-224 also had good street manners, but no vacume for brakes I think it would work better with a powermaster brake system.This cam is surely a 9 sec flat tappet, but one thing for sure you won't miss any gas stations.
Louie i'm not really trying to pick up anything right now. my rockers seam to be going out of adjustment wich makes me think a lobe is going and i have this cam sitting here but just wanted to see how well it worked for other people. Thanks man! Scot w.SW,
I dont think you will pick up anything making that swap. Keep what you have and give it hell. I went 134 with a 214 roller and coulda gone faster, maybe 137. Palumbo went 137 and change with iron heads and 218/218.
Brian PM me the price for the set please, Oh and make sure you add in the supporting customer price! :biggrin: LOL"The reason for going in at this point is a valvetrain noise"
Scot,
If you do replace the cam,and stay flat tappet,do yourself a favor and get GM lifters. We have seen many around here, and the GM lifters help this a TON!
If you can not find any, I have an extra set. Not cheap, but any new flat tappet lifter on the market will not compare to the new GM`s.
Brian
