24 years of GN Parts HOARDING garage cleaning update found tons of parts I didnt know I had
Sent pm back a couple of times now about the loom you were gonna try to take apart...check pm please need it bad lol
Never received e-mail for parts list for the 84-85 cold air conversion. Could you please text it to 765-625-1385. Thank you.
Do you still have the 86-86 upper and lower intake? If do what's the price to ship to 77066
E-mail still not received. Does the kit include the following? ECM, engine bay harness with the injector harness, fuel rail and injectors, upper and lower intake, pulleys, brackets, alternator, coil and bracket,exhaust manifolds and down pipe, turbo with feed and drain line and bell, intercooler with shroud and fan, radiator support, ac compressor with lines, valve cover with breather and oil fill tube, throttle body with all sensors, and all intercooler piping and maf sensor and intake piping. Is the price with shipping?
Ok I received the e-mail. It includes everything. I know you say $1800.00 but you don't specify with or without shipping. Postal code is 47368.
Hi intercooled. I hit you up last month about a few parts and wanted to know if you still have them. I'm looking for the glove box to the 84 dash I bought from you (dark grey), t top plastic trim pieces including the a pillar pieces ( 7 pieces total including the 2 that go on the actual t-top) that match 87 GN and also looking for the three holed sun visor holders. Thanks in advance
-All prices do not include shipping, unless stated
-NOS Turbo crank shaft $650
-New 86-87 belt tensioner pulley and bearing just like the original pulley $15
-New Blackout trunk trim $75
-New Silver(Anodized/polished what ever you want to call it) trunk trim $75
-New T-top blackout trim $50 for 2
-New T-top trim Silver(Anodized/polished) $50 for 2
-New Blackout wheel well moldings $155 a set of 4 or $65 for just one(These are just like NOS in quality)
-New Polish(chrome or anodized what evey you want to call them) wheel well moldings $155 a set of 4 or $65 for just one(These are just like NOS in quality)
-NOs pass side marker light $75
- NEW GM Passenger side Outside Black Window Dew Sweep belt molding(outer seal that presses against the door glass) $90
- AC delete bracket with belt $35
-NEW ABS backed head liner For 85-87 GN Med gray with Astro Roof $210
-NEW PUI ABS backed head liner 85-87 Med gray (Grand National) for hard top car $160
-NEW PUI ABS backed head liner 85-87 Med gray (Grand National) for t-top car $160
-New PUI ABS backed head liner Maroon for T-top car $160
-New PUI ABS backed head liner 84-87 Tan for hard top $160
-New Visors In 85-87 GN gray, Maroon, and tan $90 a set(these are new not recovered)
-New ABS Rear Bumper fillers $200
-NOS black wheel well moldings(both front and drivers rear) $200
-85-87 GN gray dash speaker cover, in really nice condition(no cracks looks close to new, but has a slight warp in the middle $150
-85-87 GN console $300
-85-87 Gray console $300
-84-85 Billet vac manifold(part on top of throttlebody) with prevision for vac brakes $30 shipping included in the US
-86-87 GN center caps $20 Each
-87 GN dash pad $140
-Driver quality 86-87 GN wheels $75 Each
-Power Master $300
-Mega shifter for Turbo 350 $75
- gray 442 bucket seats $250
-GM crate motor 350 block # 10066036 4bolt mains Edelbrock carb and intake, headers, comp cam 1.6 rockers etc. $900
-nice set of 85 Maroon bucket seats $300
-87 Grand National Engine 100% complete, runs great $2500
-New tranmission shifter cable(after market) $18
-Hot Air(84-85) conversion kit to Intercooled(86-87) $1800 Includes almost all the stock 87 parts needed to convert over to intercooled, E mail for parts list
-Turbo Riviera Turbo $200
-109 turbo block std bore $300
-Good std/std turbo crank $300
-86-87 Engine wire harness(no injector harness) $200
-86-87 Intake manifold(lower and dog house) thats been painted $160
-84-85 GN front air dam $50
-New after market cruise control shifter lever $30
-Dash plaque for a GN in driver condition $40
-86-87 stock turbo, very little play $200
-84-85 stock trubo, very little play $150
- 84 GN front and rear seats(leather and cloth) need to be recovered $200
-86-87 T-type rims(no center caps) $300 for 4 or 1 for $100
-BRF 200 4r $500
-NOS Turbo 6 emblem $50 Free shipping
-Autometer Boost gauge with A pillar single pod $25
-86-87 original MAF(not Rem.) $90
-86-87 AC compressor $100
-87 Intake manifold(lower intake and upper dog house, with metal waterlines) $200
-87 Engine harness with inj harness $230
-Turbo shield $40
-Rad hold down plate $30
-Front license plate bracket $20
-86-87 Air dams $75
-Doors $400 for set(1 pass and 1 drivers) they are manual windows and manual locks have just the start of surface rust on under side. Pick up only, I wont ship these.
-Vac brake set up $100+shipping(master cylinder, power brake booster, and correct pedal)
-87 442 Passenger side New rear quarter -Make Offer
-gray 87 442 bucket seats $250
-locking T-tops $200 a set
-84-87 RegalT-type header panel(has hole for emblem) with good black paint $200
-84-87 Nice Header panel (Hole for emblem has been filled) $200
-GN driveshaft $75
-Stock 109 Turbo long block(120k) $1000
-87 GN 109 short block, .040 Cast pistons, .010.010 turbo crank, never run $800
-86 NA 3.8 Engine complete runs good has 109 block $350
-84 NA 3.8 Engine complete runs good 290 block $250
-84 turbo Regal block .030 over $150
-85 Turbo Regal Block .030 over $150
-109 turbo block .060 over $100
-Turbo crank(Std/Std but will need to be turned at most .010.010) $250
-Under drive crank pulley and alt pulley $40
-86-87 T-type wheels(set of 4) no center caps $300
-Nice set of GN tail lights with blackout trim $160
-84-86 GN Power seat track assembly $150
-Floor brackets for console $30
-Regal doors(They have very little surface rust on under side) $150 picked up only
-Floor pan for bucket seat car $150 picked up only
-Rear quarter $150 each picked up only
-Rear frame rails $100 each
-Front frame rails $100 each
-Control arms(Front lower)$60
-Control arms(Front upper)$30
-Motor mounts(metal, frame mounts) $35
-Turbo crank(.010.010) in nice condition $200
-Turbo crank(StdStd but will need to be turned at most .010.010) $250
-NEW Felpro gaskets(2 head gaskets 8723pt-1, 2 cork valve cover gaskets,2 Exhaust manifold gaskets) $35
-84-85 Flex cooling fan $10
-85 Power steering pump(For car with power master) $30
- trans cooler $20
-B body spindles $50 for pair
-85 Maroon bucket seats $200 good condition
-85 Gray bucket seats $250 good condition
-Crank window regulators $50 for both doors
-Dash vents(with nice chrome) $20 each
-Nice Gray card board and cloth inserts(under quarter windows) From 85 T-type $30 for both
-Gray dash pad with a small hole drilled at the lower right of the drivers seat(Its not even noticable) $75
-Visors good for cores(non mirror) $20 a set
-Chrome marker light $35 each
-Both front head light bezels(need to be painted) $70 for both
-Rear center filler(The part that the rear license plate bracket attaches to) $30
-Pass remote mirror bracket(Just the bracket that attaches to the dash) $15
-NOS black plastic seat track cover for rear right side(GM part # 20023766) $20
-Frame in good condition $200
-heater box shield $15
-84-85 Shield to cover heat hoses $15
-bumperette rubber strips in good condition(used GM not after market) $20 each
-Stock factory lighter $8
-Stock Battery hold down $10
-Connecting Front Brace $25
-Front frame braces(underside) $25
-Plastic Brackets to mount front air dam $30 for 2(For both sides)
-Good hood shocks $10
-Stock turbo inlet bell $20
-86-87 engine hoist bracket(on intake) $20
-87 gray cloth Limited front and rear seats $200
-87 gray column (shift on column) $100
-87 Split bench seat power seat track assembly $100
-Original GN Quarter extensions for car with spoiler $40
-84 Red upper door panels $80 minus chromegray strips $50
-Grey T-type upper door panels no chrome strips $50
-87 Maroon upper door panels $50
-Drivers side Blackout head light bezel $40
-Chrome head light bezels painted black $40 for both
-Black trim Marker lights $40 each
-Blackout wheel well moldings $50 each
-Chrome(Regal) wheel well trim moldings $45 each
-84-87 T-type header panel with hole filled $150
-84-87 T-type GM header panel, has some small imperfections $125
-84-87 Grand National GM header panel, has imperfections $125
-Passenger remote mirror(needs paint) $60
-87 GN seat belt set(10 pieces) $150
-84 GN steering column with tiltcruise $150
-Maroon steering column with tiltcruise $150
-87 GN grey column with tiltcruise $150
-87 grey column(shifter on the column) $100
-84 Blue column(shifter on column) $100
-84 tan bucket seats $250 with rear seats $300
-86 blue 86 442 bucket seats $200
-85 Gray 442 bucket seats $200
-Gray Monte SS bucket seats $200
-85-87 Gray concert sound lower door panels $100
-GN Dash Plaque $75
-84-86 T-type dash plaque $50
-86-87 Upper intake(dog house) $30
-86-87 throttlebody complete(sensors,throttle lever, vac manifold) $100
-86-87 bare throttlebody $40
-86-87 Up pipe $25
-86-87 Cruise control assembly $40
-86-87 Water pump pulley $25
-86-87 Main accessory bracket $70
-86-87 Y bracket on back of Alt $35
-86-87 Flat Y bracket on front of AC compressor $35
-86-87 Intercooler brackets $25 each
-86-87 Coil bracket ( The horse shoe shaped bracket) $30
-86-87 Power steering res. bracket $20
-86-87 Power steering pump $75
-87 GN Electric fan $50
-84 rad shroud $30
I have every piece for 84-87 GN engines(stock) E mail if you dont see it.
-86-87 T-type wheels $100 each
-84-85 Non key locking t-tops $150 a set
-Astro roof complete assembly with wire harness, switch etc. $200 wont ship
-Bigger then stock front sway bar $70
-Fuel senderfuel hanger(analog gauge) $60
-BQ tranny $250
-Rebuilt BQ tranny $400
-D-5 convert $75
-87 chrome grill painted black(looks good) $100
Do you still have the 87 GN center caps?
Kevin
I will have to check on the 84 GN glove box.
I have some but not all of the T-top trim pieces. I definitely don't have the piece on the T-tops they are always damaged, I have the visor holders(brackets) for a t-top car. What's your zip code again?
