245's Up Front
not sure.
but my 235-60-15 have never rubbed, ever!
I would think only on tight turns would the 245 hit anything, or maybe big bump.
I have 245's up front on a 16" rim Rubs a ittle if you cut the wheel all the way
stock was 26.1 tall ,
the 245s titan spoke of on 16s are 245/50-16 and they are 25.6" tall (but still 245mm wide when new but the edges round off quick) mine were probably less than 25" where they rubbed the fender liner with gta rims
the 245/60-15 you asked about are 26.6" tall and still 245mm wide so plan on them rubbing on turns more than those guys that run gta fronts with 245s and mostlikely hitting inside the fender on bumps more often too , i wouldnt run taller than stock upfront
as cruzn posted the popular upsize for front with 15s is the 235/60-15 which is 26.1 tall
not much else available for the 15 rim
thanks pacecarta that's what I was looking for. I'll probably run 245's in the rear if that makes a difference.
