S
Stephen Soulsby
Guest
I'm still chasing the stumble and general poor running of my car
I pulled off the left valve cover to take a look around and here is what I noticed. With the motor at TDC both valves are supposed to be completely closed right? When you take out the bolts for the rocker shaft, the #1 (and other) valves lift about 1/4" and are sealed against the head. When I installed the rocker arm shaft, the valves went back down about 1/4" into the combustion chambers. If I'm not mistaken this would mean the valves are floating all the time, correct? My car only pulls 12" of vacuum at idle and 10" in gear. There are NO vacuum leaks and the Snap-On scanner shows nothing unusual except the unstable idle, and O2 sensor readings. The car acts as if it's rich and lean at the same time. If I lean it out to 36 it knocks severely and won't rev past 4,250, but if I richen it up to 40psi it still knocks and my O2 is at about 950 and still knocks. Every manual I have looked in says what I already know about the valves being non adjustable.
The reason for the subject title is I'm using heads, rocker arms, and pushrods from a 252. Could there be some type of conflict between the block and heads?
Or are my observations of the rocker arms and valves normal?
