On the 11.32 pass, my 60' was a 1.601; and the tires did break loose a little bit, but hooked right back up. Boost was up there, it pegged my 3 bar MAP on the first pass. So I'm gonna guess it was somewhere in the neighborhood of 28-29 pounds...
It helped that the track was well prepped and the air was good.
My car is a basic street/strip setup.
Stock motor w/125K, stock heads & cam, Comp 980 springs and Edelbrock double roller chain
200-4R out of my T-Type, mostly stock, CK shift kit & servo, Alto band and direct clutches, 10 vain pump, Art Carr pan and 700R4 filter. Stock DS with solid u joints.
TE-62 journal bearing w/ .63 A/R exhaust housing
Dutt neck IC
3" THDP with Hooker exhaust and a cutout
MSD50s, 340 pump, Accufab regulator, stock lines
PowerLogger and TT 5.6 alchy chip
all the other stuff too.
Rear suspension is mostly stock. Stock, fully boxed LCAs (w/ rubber bushings), original uppers, Kirban cargo coils, dual airbags, KYB GR-2 shocks. And a Full Throttle "ATR-style" rear swaybar. Big shoes and big cylinders in the rear brakes. I can hold 10psi+ on the vacuum brakes.
Its a full weight/full interior street car.
Hope this helps.
