275/60 15 on eibach lowered car?
Not sure about that but I cant even get a finger between the tire and frame on mine, If I ran Aluminum drums I would have more clearance but it would be closer to the fender lip then.So it must be that its a taller tire .
I have a Moser 9" that is supposed to be stock length. It has a Wilwood Rear Disc Setup. I have Eibach springs all around and am looking to get a pair of 15x8's for the rear. Should I go 4" or 4.5" backspace?
I would say try a set on yours first , there's got to be some guys buy you with this setup?
Looking at most of the common 15" wheels for the 5 x 4 3/4 bolt pattern have 4" BS. I have seen alot of 17" running 4.75 BS and not have a problem. I guess I will look at 4" BS later next summer when I plan on getting new wheels and still debating on 275/60/15's or 275/50/15's. I like the thick sidewall, muscle car look but a LITTLE worried about to much rubbing.
