295/65r15?
iNfested
Just wondering if our cars can support a 295 wide tire without body modification, or is 275 the max? thanks...
Hard to answer, kinda one of those "depends" type things. Depends on how well centered the axle is, etc.
BUT.... a 65 profile tire in 295 size is going to be awfully tall. You sure you want one that tall?? Maybe a 295/60 or 50 would be better.
I had a 295/50/15 on my car for the last few weeks. It had about 3/8th of and inch clearance on the frame rails. The outer part of the tire hit the fender lip from time to time on bumps. I have air bags and 15 psi in each bag. As for the rim I believe it is a 10 inch wheel. I’ll have to check tonight the offsets and width.
Just installed 275/60-15's on 7" rims. That's about it if you want to avoid issues. Can post some pics if you like.
I have some 295/50-15's on 8" rims (79 trans am). I'm curious to see if they would bolt up to my Regal, but I doubt they would make it.
Running MT ET Street DR's 295/55-R15 (28" tall) on 9" rim.
Diameter - 27.9"
Section width - 12.0" on a 9.5" rim (about 11.5" on 9" rim, 10.8" on a 8 " rim)
Tread width - 10.8
Approved rims - 8-10.5
from MT rep on yellowbullet.com...
The P295/55R15 is a replacement for our 28.0/10.5-15 ET Drag and the 28X12.50-15LT ET Street. Race tires are designated by tread width, street tires use section width.
If you are running the 28X11.50-15LT ET Street (# 3754), and can't go any wider, you'll wnat to use the P275/60R15 ET Street Radial (#3754R)
Last pic is next to my 255/50-R16's on stock 8" rims.
