turbo87regal
- Nov 12, 2005
I recently had to change out the forward drum in my transmission with a billet one my stock one broke. While I was in there I was advised to do the 3/2 control valve update for my older CK shift kit witch I did and the only other change I did was installing a bigger boost valve in the pump.
Transmission is shifting much better into 3rd under heavy throttle witch is what I was after but I took the car out the other day and got a very wierd shift (seems like it went back and forth between 2nd and 3rd very quickly about 3-4 times) while under light throttle. It did this twice and only under light throttle under heavy or moderate throttle its fine. Also 1-2 shift is a little harsh to me now under light throttle compared to what it was before.
Is this a normal side effect of this mod, could I have done something wrong and what can be done to fix it?
