SignUp Now!Originally posted by Louie L.
Funny you mention this here. I have also considered the same. I was informed that the issue may become the rod bearing surface when using the Eagle crank.Thi was not a conclusive answer but based solely on narrow Vs wide journal usage in high HP apps. Maybe someone can chime in and give a definite answer on building or having built a similar motor(narrow journal/ high hp/off center...)
Originally posted by BUICKTR
So on a 4.1 S2 oncenter block can you get a matching rod for the Eagle crank. Would have have to use for example a Carrillo, Crower, Cunniham rod (oncenter)
Thanks alot for the info. Would you know the estimated power this combo would have with ported GN1 alum heads, billet solid roller cam (224/224 or 236/236), forge pistons, 9 to 1 compression and a PT 76 GTQ turbo. Thanks again!
