well im going to put my 3.8 motor i have from a MONTE CARLO in the s10 because i ran in to some problems on the 283 so now im going to do a mild build up on my 3.8 my ?'s are
im doing a mild build so should i use a after market timeing and lifters or just a cam also will the 4.3 vortec heads fit seens it a 90* v6 too if so what year 4.3 heads should i use im looking in to a new intake and carb too also as far as motor mounts could i use the stock frame motor mounts from a 4.3 and who makes a good header as far as price and how good it really is
will the 3.8 motor bolt up to my 2.5 trans to if so what kind of work will be needed
what all do i need to run no ecm im thanking maybe all new wire the s10 wire has seen better days + im thaning about a aftermarket HIGH-PERFORMANCE ELECTRONIC IGNITION SYSTEM and a DISTRIBUTORwhat other stuff should i use and waht all do i need to make it driveabel on the road any info i get i can use to get a better ideal
note im runing a 84 Monte Carlo 3.8 v6 motor in the s10 im waning to use aftermarket mph and rpm gauges so someone told me the 90 4.3 trans had waht i need will that work
