SignUp Now!lowest I've heard was 45 lbs at idle which be fine for me with the chip I'm running maybe some will chime in
I just bought a reds Armstrong xp which I think is a walbro 340... Hope I won't have any issues! I plan to run e-85 though.
I had an Aeromotive 340 pump with stock lines with no issues as well. My idle fuel pressure did not change.
Don't know but I'm putting mine in tomorrow would be nice to know for sure I have read it both ways the lowest I've heard was 45 lbs at idle which be fine for me with the chip I'm running maybe some will chime in
Finely got the pump put in today when to install last week and noticed a wet spot on my gas tank had a hair line crack on it so I had to wait for a new tank the install went really well about as simple thing that you can do to the car it assure consistent fuel to the injectors fuel pressure was 40 before with the other pump with the new 340 it's was 48 with no changes or adjustments haven't tried to adjust it yet just put a new transmission and convertor in today also and was verifying line pressure to make sure every thing was up to par before I take it off the lift and then the ice storm hit so I'll try to adjust tomorrow and see if the fuel pressure will come down a little it was idling fine don't know what the ill effects would be if it was a little high car didn't smell rich if I can't adjusted down ill probably just take a little fuel out of the gen-2 getting 5-8 inches of snow tomorrowHow did your install go? Started mine up for the first time today and the fp is high
They have always been around 128-132 why would they change with a pump change?
Mm
