- Aug 1, 2003
question
i installed the 3 bar with the PAC kit and noticed my stock indash boost gauge is way off (low) ...not a big problem since i run a seperate boost gauge but just curious incase i decided to go stealth and remove the aftermarket gauges once its dialed in
i dont know if it has to to with the PAC controller tap of the map signal wire (didnt cut just stripped back insulation ) or is it just the 3 bar map
is there something i can to do to bring it back to being accurate or can i just swap back the 2bar map and run with that.
is there a downside to using the 2bar in an alky setup?
