I hope this is the right section for this post......
I had a few people ask me to keep them posted about the install, fit, and performace of this pipe so instead of repling I figured I'd share with everyone...
the good:
the craftsmanship is excellant!....
no clearance issues at all (my body bushing are fairly new)...
My turbo spools a lot faster!
Sounds bad a$$ when the dump cover is off...
as you can see in the pictures I used very basic cheap hand tools and a set a ramps to do this..
The other:
my old pipe was a mother to get off...if you have a lift or you can get your old test pipe off it should be a snap I had to cut the test pipe in half to get it out..
I had to cut about 1 and 3/4 inches off the DP to make it bolt up correctly to the "y" pipe that goes to mufflers......this could have been a problem with my exhaust.
thats it! took about an hour and a half.......
will know more on the performace end next thursday grudge night!!
heres a link to the pics......
First 2 pictures are of my security system
jcawley3/downpipe install - Photobucket - Video and Image Hosting
the good:
The other:
