3M-Trizac
jim0207
INVNO1
Trizac foam back sanding products is appealing. Has anyone here tried there 1500-3000-5000.
I use the 3000 quite a bit. The 1500 seems to leave hooks some times in the finish. I have used the 5000 also a few times. I like the 3000 the best, usually wet sand with 2000 by hand first then use the 3000 on a da and buff after that. I use presta buffing compound on a Wizards buffing pad. On black I do finish with 3m though.
I use it all the time. Kind of expensive but takes a lot of work out of the finishing process. I use nothing but 3M compounds and pads.
