I've been out there for a while, and apparently, (Should have remembered from my EET classes) that you should test with an ACTUAL METER and not the LED test light like I was! The brake light switch pushed enough current to light the led, but not enough to light the bulb! LED didn't have enough when I tested the blue wire with the bulb in the socket! (Less than a volt?) Jumped the wires at the switch and it lit up, so I guess I'll buy a new switch.
Dan Buick Man, Thanks for the suggestion, I appreciate it!
