3rd gear and 4th gear pressure switches
Brooks
Hi all, recently had my tranny rebuilt and noticed on direct scan that it appears my 3rd and 4th gear pressure switches are out of wack.
Direct scan indicates that I'm in 4th gear until the transmission actually shifts into 4th, then direct scan shows I'm in 3rd.
I haven't dropped the pan yet to pull the switches. I'm assuming that both switches (3rd and 4th gear) need to be replaced... Local parts stores seem unable to help. Does anybody know the part numbers for these switches?
Charles Brooks
The 3rd gear switch stays on in 4th.
Without knowing the particulars of your chip, if the TCC is acting OK, you might be fine.
BTW, Merry Christmas. :)
cross
Sounds like the wires may be crossed. Altho, unless the wiring has been messed with, I don/t think the 4th wire will reach the 3rd switch. When it goes into 3rd, the 3rd lite should lite, when it goes into 4th, 3rd will stay lit.
