Call the people who manufacture your particular ring package. They will tell you how to finish your cylinder walls. Typically,there is a relatively rough initial hone which creates diagonal channels that hold oil.They need to be a certain width and a certain depth. When the stone cuts them in, it creates peaks/mountain tops and valleys/channels. A common stone to use during this process is 280 grit The next step is called plateau honing which sands the tops of the mountains which creates flat areas/plateaus on the tops of the mountains, To accomplish this,you use a much finer grit stone typically 400 grit. There are 2 methods to accomplish this second step. A nylon bristle bore brush. The bristles are made with an abrasive mixed into the nylon. The ring manufacturer will typically tell you to give the bore relatively few strokes clockwise and counterclockwise. The other method is to use one of those ball hones. Typically,you will use one with 400 grit balls on it and will also give the cylinders very few strokes in each direction. Before we started plateau honing,the tops of the mountains were filed flat by the rings moving up and down in the bores during initial start up of a freshly rebuilt engine, This created alot of shrapnel and the rings needed more time to seat. With plateau honing,we get a very good ring to cylinder wall seal immediately.
