...........not sure if someone has tried this before? im sure it has been done?? please some one chime in im by no means a professional engine builder im throwing ideas on the table for something new? should i try this does it make sense? or no?
Yes, this has been done before with a Buick V-6.
Your post leaves out the reasons or reasons for doing this? Is there a specific race class that requires this, or just a whim to be different?
I have been around race cars before turbos, and a cardinal rule is to increase displacement for increased HP. As far as I know, this works for turbo applications as well.
Also, most drag racers pick increased bore over stroke when given the choice as it can greatly help breathing, and HP in most cases like what was mentioned above.
The de-stroked turbo V-6 I was associated with for years in NHRA class racing was run to 9000 RPM to obtain the needed HP to help compensate for the small displacement.
My personal preference is a 4.1 over a 3.8 for street or strip because of more low end torque. My opinion is that a shorter stroke will hurt, not help, low end performance in your case.
As far as your comment, "cylinder fill will be worked by the turbo", I am confused how that is a factor assuming you have the proper combination including the turbo?
Good luck on whatever you decide, hope it works out for you!
