Feb 2, 2017 #21 E earlbrown runs with scissors Joined May 26, 2001 Messages 7,539 That might be a trick since the 4.1 uses shorter studs/bolts than a 109 block. I'm guessing the GN1's have different height bosses than 8445s?
Feb 3, 2017 #22 ek02 Well-Known Member Joined Jan 31, 2008 Messages 1,226 I used the studs Champion says to use on my 4.1 with GN1's for a 109 block and some were too long and some too short. I ended up mixing in a set for an early 3.8. I had to use double washers on the long middle studs from the 3.8 set. Last edited: Feb 3, 2017
Feb 3, 2017 #23 E earlbrown runs with scissors Joined May 26, 2001 Messages 7,539 Sounds about right. 3.8 blocks let the studs sit lower relative to the deck since the top threads are missing.
