SignUp Now!Razor said:It will bolt on the same. Oil pan is different, and the theory is the sides of the block are not as strong. Dunno.
The TTA heads will work on it.. finding a girdle for it may be tough tho..
I usually leave the blocks at the junkyard and snatch the cranks out of them.
There is a lot of casting flash in the lifter valley area.. at first looks weird, but theyre all like that.
HTH
87gta-turbo said:You CR will go up unless you have custom pistons for it. Very few off the shelf pistons to begin with on the 4.1 for the Buick.
No, the 4.1 will be a 14 bolt pan and the 3.8/TTA pan will be a 20 bolt that means the front cover will be different too.AKTURBOTA said:Will the oil pan from the 3.8 in the TTA bolt to the 4.1?
87gta-turbo said:No, the 4.1 will be a 14 bolt pan and the 3.8/TTA pan will be a 20 bolt that means the front cover will be different too.
Although they make the new front covers with dual bolt pattens and seal that can be installed/replaced with out pulling the front cover for $90.
Which is what I went with.
The GNttype.org article states that the 484 block is the most desirable which is not the case. they are prone to cracking from bolt hole to water jacket. Look here:
http://www.turbobuicks.com/articles/4point1ForCheap
