Well if all you want is torque and no HP, then you should swap in a Cummins Turbo Diesel engine! Dude just think about how much tire you could peel with that since its all torque! WOW you could like maybe even do wheelies.
Time for a lesson in mechanics Matt. Torque (defined as a twisting effort) is what not only gets you off the line and down the road. Horse power (defined as how much work a horse can do in X period of time) is what keeps you moving after you get to your target speed. You can have low HP numbers and high torque and be much faster than the guy that has high HP numbers and low torque. That's one of the secrets of the Buick motors. They produce much better torque which propels them down the track and keeps the torque going at a higher RPM.:biggrin:
