4.1 Racing short block complete!
cswrench
1984 production 4.1 Liter 484 casting number block that has been magnuflux checked with zero cracks anywhere including the deck surface where some 4.1's are known to crack. The block had the lifter valley casting flash cleaned up, hot-tank, new Clevite cam bearings, bored .020". The block head bolt holes have been radiused, and also drilled/tapped for the factory turbo oil return line. Here is a list of what it has:
- .010"/.010" turbo crank
- Federal Mogul "H" series rod and main bearings
- Billet caps with ARP studs
- Modified front cover with oil boost plate and oil filter adapter
- Stock rods reconditioned with ARP bolts
- .020" Federal Mogul hyperutectic pistons
- Total Seal second ring gapless rings
- GM oil pump pickup tube
- -.005" under Cloyes double row timing chain set
- 84 GN oil pan with baffle modified to flip the drain plug to the outside, powdercoated, magnetic drain plug
- 214/224 Schneider cam with lifters
- New design cam button
- Water pump
- All stainless fasteners
Just needs heads, pushrods, intake and headers. All brand new!
Located in Indianapolis,IN Will ship via freight at your expense.
1900.00
interested in the short block. can you send me some pics? i also i have a 84 stock long block converted for a 87 and a rebuilt 6109 block if you maybe interested in any trading. interested either way. my cell phone is 1-347-680-8642 in NYC.
