what's the new car?I no longer own the car or motor but it went a best of 9.58 on E85. There was more in it that was conservative boost and timing. 28 psi and 21*. I was sorry to see that one go but i needed to sell it to get the new race car moving.
I no longer own the car or motor but it went a best of 9.58 on E85. There was more in it that was conservative boost and timing. 28 psi and 21*. I was sorry to see that one go but i needed to sell it to get the new race car moving.[/QUOTE. That's very quick. Especially with 120lb. Injectors on E85 . I'm so tempted to switch over to E85 & give up my 93 & alchy.
How much fuel pressure did you push at them?injectors were done maybe a little past done lol
Did you,by any chance,use SMP 120s?around 55 base as I recall, 680 racetronix double pumper never let me down kept up fine
I get the impression,from my own experience,that these flow an actual 120. I think the actual flow of the Delghi 120's,for instance,is 111i did yes
I bought mine used and am very pleased with them. I also like the looks of them. Glad to know that you had success at higher pressures. I'll be keeping that in mind.the delphi is definitely less they also tend to lock up at higher pressures, The SMP is impressive for the money..
Compression ratio?I no longer own the car or motor but it went a best of 9.58 on E85. There was more in it that was conservative boost and timing. 28 psi and 21*.
