4.1 stroker JE Pistons & Carrillo rods combo
BlownV6
Ok for you 4.1 guys I have put together another stroker kit for you. I have a set of JE pistons with pins & the rings (all new) and a set of HD carrillo off-center rods (used) for sale. With a 3.625 stroker crank in a 4.1 block bored to 4.010 and a stock deck height of 9.535" and turbo heads at 48cc this combo will yield around a 8.91 to 1 compression ratio with a .062 gasket. Pistons , pins , rings & rods shipped to your door $675.00 Mike:cool:
Mike- can I just buy a set of heavy duty pins & rings for a 4.005" bore- I already have pistons and rods from you.
I dont have very many sets of rings but I would need a lot of info on what size & thickness the grooves are. You probably would be better off letting your engine builder determine and get your rings for you. Wrist pins I need the actual diameter required & length that the pistons require and how muck power you want to make. Mike:cool:
Narrow journal pictured , I also could make it wide with a different set of rods if required. Mike:cool:
