mikemcvaney
- Apr 20, 2009
Pm with a priceI have a set of GN1 valve covers if you need them...
SignUp Now!Pm with a priceI have a set of GN1 valve covers if you need them...
Can't run NOS or boost on the FAST. But I have an ecm that will.New topic what brand rooler rockers TD orHarlan sharp ?And Damm that FAST ELECTRONIC INJECTION looks tempting like huge tit tempting. Just think alky and nitrous with self learning if I dont like it can always run it on blow threw super charged small block ford
Yes you can. You can have separate tables for the nitrous alsoCan't run NOS or boost on the FAST. But I have an ecm that will.
Brian he is thinking the EZEFI TBI style of system, not XFI, I would agree 100% on classic or XFI.Yes you can. You can have separate tables for the nitrous also
That's the bad thing about the ez efi, no boost or nos tables are in the ecm, look up dynamic efi they have TBI capable systems for boost or nosyes ez efi
Thank youThat's the bad thing about the ez efi, no boost or nos tables are in the ecm, look up dynamic efi they have TBI capable systems for boost or nos
I just read through and didn't notice if its a blow through with a 4.1 intake or a suck through with an early carb turbo intake. If blow through around 38-40lbs/min if suck through 26-28lbs/min with the boost around 18psi at sea level. On high octane fuel you can run all in with the timing adjusted for it.dropped myh carb off to get wet flowed and the intake to get ported and flow balanced hopefully this thing should be done shortly. Anyone want to guess at thye dyno pulls having one pull at 11- pounds boost 93 octane and one at 16 to 18 pounds on race gas dont think I can get much more boost than that because of heat. So guys tell what you guess and will see whyo hits theclosest to the number. dont know if thyecam was posted its a 210 216 extreme roller
Long time no see. Looks like you have been keeping busy. So what did the motor pull on the dyno?
Are you porting the stock intake? What brand cam are you running? I am really interested because from my memory we have a setup almost alike... your running the 301 turbo correct?
Matt it is a full throttle roller and a factory 80 aluminum intake was going to have it extrude honed but thought putting it on aflow bench and having it ported and flow balanced is about the same or cheaper than extrude hone . The specs on the turbo are posted on this build it is not a 301 housing its ahogged out stock compressor housing wanted it to spool fast it is a daily driven street car that goes on several hundred mile cruises frequantly it spools real fast loveit. My girl freind died of cancer on holloween that kept me busy for the last year, Im back on track guys with a clear head a little more mocking on the speed daddy headers uppipe a oil tube for the aluminum valve cover and Im going to make a holley adapter plate on the cnc and weld it to the plenum, Any other questions Matt just ask thank you guys for your input always helpful . MikeLong time no see. Looks like you have been keeping busy. So what did the motor pull on the dyno?
