4 AN supply line
Bescurred
BOOSTED SHAMU v2.0
My turbo saver supply line has started to leak. Called Precision to get a new one and tried a couple of hydraulic hose places around. I need one side that is 145-150 degree angle then about 2 1/2 feet of stainless size 4 line then a 45 degree angle. Do I have to go through summit of jegs and just make a new one? Or does anybody make said line ready to go?
If its just the fitting its not very hard to swap a new fitting in there.
x2 dont be bashful with some type of lube on the fittings when assembling since the fray and or the alum can get chewed up.
I'm pretty sure its the hose it's self, but just to be safe i'm going to get all new fittings and a hose. I'm just afraid of effin' up my turbo lol.
Just flush the line before you install it and you'll be fine
Not sure what you are asking. Its the original line from precision when I ordered the turbosaver. Its a stainless steel line with the rubber inside I believe.
Exactly what I was asking... The rubber liner can/will get brittle due to having hi temp oil pumped thru it, for who knows how long...
When mine failed it started to seep through the hose outer jacket about midways from turbo to TS and dripping. I replaced the fittings with black ones and it looks much better than the Blue and red IMO.
Gotcha, thanks I went ahead and ordered new parts.
That's exactly what mine is doing. I just ordered the blue and red since they are hidden anyways. Maybe next time I'll do that, does sound nice.
Thanks for the help fellas.
