4" Cold air pipe - NO MAF
Blazer406
Mechanical Engineer
I want a good looking pipe to go from a 4" inlet turbo to the 4" part of my big mouth cold air kit....
Planning on re-locating my LS1 MAF meter in the up pipe.... this will mean a straight shot from the air filter to the compressor inlet....
Any ideas?
I believe the ones available from RJC racing don't have any type of sensor, meant for people either not running one or relocated it:
INTAKE PIPES
Why not just one of mine? You already have my cold air kit. :) 4" INLET Pipes
Does it hurt the MAF when you run it in the up pipe with alky???
It will be installed before the alky....
I'm gonna get the big turbo on there and decide what to do from there... gonna break in on a stock turbo for a thousand miles or so.... then plan on stepping up to a 70 P trim with a H housing... 4" inlet... 3" outlet.
I want no restriction getting to the turbo... with the MAF meter out of the way....it will be no restriction getting to the compressor wheel....
I used the 4 incher from RJC and got a new polished 45deg elbow from Mark to hook up to my existing big mouth setup - turned out very nice.
You can't see the transition to the elbow but you get the idea. This is the best fitting one-pc inlet pipe I've ever used.
I have a nice powdercoated silver pipe from Full Throttle (before they started putting sensors in them) that I am thinking of selling.
I have the same set up. I have the 3" Big mouth, but just bought the 4" RJC. Did you have to cut the RJC pipe to make it fit?
Mark,
I may be looking for the same set up too.
Sorry for the high jack. :biggrin:
Mark,
I cut the elbow instead - the RJC is made extra long so you can go either way.
