Someone posted a link to a company who makes a replacement proportioning valve for the G-BODY, but I can't seems to find that link now. It was for like $89 for this replacement part. Any help would be great. Thanks
I found it guys, the company that makes the 4-Wheel Disc Brakes (stock location) Proportioning valve the the G-BODY application is http://www.inlinetube.com/
p/n VBU107 is the stock replacement for $85 and if you want one for 4-wheel disc brakes, it is $99. HTH's.
You might try just taking the stock one apart, and blocking off the various ports, and the *knew over valve*. Mine is now basically just a junction block. I've used it with the PST rear discs/ B-Body 12's, and now with my LS1 front and rear brake conversions.
The Master Cylinder I'm using now, have a fluid level indicator in it, so I use that rather then the pressure differential switch of the oem setup.
