400 cooler output ?
Brad T
Is the top line the in or out ? Iam putting a gauge in to check the line pressure on start up and would like to have it in the right line the first time .
I also have the Jiffey Tight disconnects in the cooler lines . Anyone had any bad luck with them ? I am thinking about taking them out just to be on the safe side .
I think the top is the out but I'm not 100% sure on it.
A local had the quick connects on his T-400 and it tightened his converter WAAAAYYY up. It had to be some kind of restriction. He took them off and the stall went back to where it was. I'm not sure what brand he was using.
TH-400 cooler line output is the lower fitting, return on the top fitting
200-4-R cooler line output is the top fitting, return on the lower fitting
x2 on what Dusty said...... some of the quick connects that I have seen are restrictive
