Im running one on a twin turbo 408 dart SBC,CSU built the carb and its great,100% on and I have a dual FAST wideband to monitor it and all is good...I run the MSD BTM with a controll inside for timing retard that runs off vacuum,I run a Aeromtive 1000 with a fuel regulator that runs off vacuum..
Let me see,the good...Cheaper,easier to tune for me and I dont have to run F.A.S.T to go fast and I dont have to have anyone jump around inside my car after each pass trying to tune my car on a laptop..I wouldnt run a F.A.S.T system with fuel injection if someone gave it to me and hooked it up for free...I will never need help tuning as long as I have a screwdriver...
Bad- maybe not as good on gas,but when your running that kind of motor I doubt you really care....And when the weather changes,you have to adjust the air-fuel old school with a screw driver instead of the computer doing it..
My car put down 628 at the rear wheels @ 5200 RPM on 12psi..I have been to 20 PSI..We were running lean and I let out but it was instant power and it had alot more in it with just the 12 psi,I cant imagine what 25 psi would do once I add the methonal...Right now it does 45 MPH burn-outs on et streets with 5psi!!
