Jun 28, 2006 #1 9 9SECVSIX Member Joined May 25, 2001 Messages 520 Is .075" to much clearance on the 4th clutch pack If so I need cut another piston I cut the piston down per the manual and added a extra clutch. thanks 9sec
Jun 28, 2006 #2 WE4 TBcom Admin /Prayers NYFD/NYPD Joined May 24, 2001 Messages 4,594 Well... You are fine. Run it! Bruce We4 www.PTSXTREME.COM
Jun 30, 2006 #3 C chris718 Active Member Joined Dec 10, 2002 Messages 5,356 loose is good for that pack as it will otherwise cause horsepower loss in the first three gears when the pack is not applied and is just dragged along by the overrun basket.
