5.7 tt chip for e85?
bpman1234
eric this ones for you i got this chip and injector combo it was purchased from tt my ? is the chip was set up for a bigger turbo i think a 60 and i have stock turbo can i run this chip with my almost stock setup with some adjustments that i can do my self with foot pedal ?or will i have to send it in to you?also if i send it in will i be able to make it a 6.1 please reply thanks
You would most likely have to set the WOT fuel as low as it will go, so the fuel curve would be a little funky. You can try it and see, but it might need to be reprogrammed.
It can be converted to a 6.1 chip also.
Whats the charge for the conversion and programming.
Sent from my LG-MS910 using Tapatalk 2
hi eric just placed an order and paid just want to so know all i have to do is send you the chip above ?order #10777,thanks
Ok, but...
You ordered a 5.7 chip.
Here's your notes in the order:
"want to upgrade to 6.1 for use with gen2 for wideband tracking and my combo.thanks"
A 5.7 chip is not a 6.1 chip. Also, a 6.1 chip is not really made for a Gen 2 Translator.
The proper chip for a Gen 2 is the Extender Extreme G chip.
For wideband tracking, you can either use a 6.1 chip with a Powerlogger, or an Extreme G chip (if you have the wideband connected to you Gen 2, which doesn't require a powerlogger).
So, what is it exactly you're looking for? Then we can figure out what chip you need.
Regards,
Eric
I have the Gen2also have the powerlogger also have the LC one all connected right now I'm using the pro chip but I bought this e85 combo so I can go e85 I have the three and a half inch maf
