Jun 29, 2013 #1 S Sweet6 Well-Known Member Joined Jun 12, 2001 Messages 3,547 works perfect $30 shipped
Aug 3, 2013 #3 T turb0buick57 Member Joined Oct 10, 2009 Messages 463 What combo is the chip for? Posted from the TurboBuick.Com mobile app
Aug 3, 2013 #4 S Sweet6 Well-Known Member Joined Jun 12, 2001 Messages 3,547 I used it on stock motors with with a GT3255 and a TE63. Since it is adjustable it will work with a wide array of setups.
Aug 12, 2013 #8 T T-Bone 67 New Member Joined Aug 2, 2013 Messages 13 Nice, Would it work with a bone stock 85 gn? also what kind of power can you get out of it?
Aug 12, 2013 #9 S Sweet6 Well-Known Member Joined Jun 12, 2001 Messages 3,547 it is for an 86/87 set up.
Aug 12, 2013 #10 T T-Bone 67 New Member Joined Aug 2, 2013 Messages 13 Oh well. thanks anyways. The more i work on this car the more I realize there is less love for the hot air buicks than the 86/87s.
Aug 13, 2013 #11 Q QwikStop Wfo Racing Team Rep. Joined Jul 16, 2012 Messages 474 Are there any other details on this TT chip like what boost psi is it set for? What timing is it set for? Is it set for 50 lb Inj. ? I'm interested but just don't know a lot about them when it comes to application.
Aug 13, 2013 #12 S Sweet6 Well-Known Member Joined Jun 12, 2001 Messages 3,547 Yes it is set up for 50lb injectors Since it is an alky chip you can run berween 17 and 30 lbs if boost
Aug 13, 2013 #13 S Sweet6 Well-Known Member Joined Jun 12, 2001 Messages 3,547 The base timing is 21 degrees but it can be adjusted if u wanted to change it
