55lb lowZ injectors and Extender Alky chip (+3 other chips)
forcefed86
Just pulled from my car a few months back. Ran great. I switched over to E-85.
The 2 up to date chips are a turbo tweak and a extender. both burnt for alky (21* timing)
I have 2 old school reds chips one with 18* pump gas timing and one with 21* race gas timing.
Asking $225.
injector is stamped
Siemens Deka 3102
How old are the injectors are they flow matched? And can they be used with stock ecm? thanks
they were flow tested when i bought them in 2009. All within 3% of each other. Removed from my car earlier this year when i switched to e85. u need a resistor box, or modded ecm to run these. i explain this in my post.
How about $190 SHIPPED! With extender chip, Turbo tweak chip and 2 reds race chips. 18* and 21* timing. Oddly enough I got my best ET on the Reds race chip. Best streetability on the Turbo Tweak. Most tuneability with the extender.
Guess I can't go back and edit posts now? Anyway if you use a resistor box from a dodge stealth, Mitsu VR4, or toyota supra (MKIII years) And wire it like below, you can run these without a modded ecm.
  • 170627d1270937930-injector-resistor-box-wiring-how-20to-20wire-20resistor-20pack.jpg
