6.1 Question For Eric
SCOOBY DOO
BASED CANADIAN PATRIOT!!
Eric, if parameter 4 is shut off on your 6.1 chip, can you adjust high gear fuel only or both low and high gear fuel via NB.
If wideband correction is turned off, there is only one WOT fuel parameter for all gears.
You can turn off WOT closed loop correction by setting the target AFR's to 9.9 (99). Params 1,2, & 3.
