60mm wastegate blitz DUAL SBC ID boost controller driveshaft loop & more
ericttype
  1. blitz boost DUAL SBC ID SPEC R ELECTRONIC BOOST CONTROLLER $250
  2. driveshaft loop $60.00
  3. hotwire kit wire was repaired works fine $40.00
  4. 60mm wastegate new $160
  5. 15ft new of greenshield 3/8 fuel line rated to 225 psi $40.00
  6. 13+ft russel fuel line w/Y more then 15ft comes with 2 fuel filters $140
  7. rear battery relocation kit wire all new ends ect, the box is used $60.
  8. turbo heat blanket t3 t4 $45.00
  9. tilt steering column good shape needs to be cleaned $175
  10. buyer covers paypal fees
Dibs on 60mm w/g pending more info. What brand, etc. also # 5, 6, & 7.
What size is the russel fuel line?
#5 is rubber 3/8 fuel line its rated to 225psi barocode green shield the best, #6 has all #8 fuel fittings that is just ubder 1/2" i had a dual feed fuel rail i was using still have, the wastegate is off brand no name
Sorry I haven't gotten back to you, I'm trying to find an assault rifle and the gun shops are empty! I'm going to pass on #4, #5, & #7. PM info for payment of #6.
Thanks,
Tom
