60's era HP vs. modern hp rating?
Ssg Ken
We all know the 60's cars hp was off. My Dad's 1966 325 hp Bonneville has 10.25 compression and was doggy. My 1960 348 tri power with 10.75, and whatever the Trophy engine had was Way more powerful than 7% more. The Bonneville was pumped up and mine maybe about right or it was down.
I read many years ago that once the hp ratings were truer which meant a: water pump, fan and radiator instead of a cold water hose, alternator instead of giant battery, Detroit winter air supplied through a vent through the wall, mufflers instead of pipes again to the outside and I am not sure what else, that is you took the rating and gave it 150% it would be about a 1965 rating.
If this ever worked it likely does not work with today's 425 hp cars from other producers than Buick. I think they meant a 150 hp V8 1980 Buick might have been like a 225 hp rating in the 60's.
Does anyone have any thoughts on this?
used "flywheel" hp years ago.. now it's "rear wheel hp" I forget the % of loss (maybe 8%) with rear wheel power:cool:
i copied this from some reading
Flywheel vs. Wheel HP
As most people know, there are power losses through the drivetrain so wheel hp is always lower than flywheel hp. Front wheel drive cars with transverse engines tend to be more efficient than most rear drive configurations due to the layout of components. However most publications overestimate these losses considerably.
Most rear drive cars have a 1 to 1, 4th gear which means that the power path goes directly through the mainshaft of the transmission. The only losses here are bearing drag which is less than 0.5% and the viscous drag of the gears running through the oil which is about 1% with hot oil. Indeed, published data indicates a transmission efficiency of 98 to 98.5% for conventional transmissions in 4th gear.
Losses within the driveshaft account for about 0.5% if they are properly aligned, balanced and with fresh U-joints.
Differential losses in the commonly used Hypoid type gearset is in the order of 6 to 10%.
The worst scenario case for a rear drive setup is on the order of 12.5% in 4th gear, not the 20 -25% often published. If 25% was being lost in the drivetrain, the oil would boil in the differential housing in short order and aluminum transmission cases would fatigue and break from the temperatures generated. On a 200 hp engine, something on the order of 37,000 watts would have to be dissipated out of the transmission and differential housings. Obviously, this is not the case.
Transverse, front drive transaxles usually have no direct lockup gears and no 1 to 1 ratio, however, since the torque path is never turned 90 degrees as in the rear drive setup and efficient helical gears are usually employed for the final drive set, losses are more on the order of 6 to 9 percent in the upper ratios.
Tire pressure and wheel alignment can have very significant effects on losses at the rollers. Tire pressures should be set the same between each test. Tire rolling resistance varies inversely with speed, another factor not taken into account by most chassis dynos when applying phantom flywheel hp formulas.
Comparing the Numbers
Many novices are quick to compare hp numbers between chassis and engine dynos and come up with all sorts of wild conclusions about drivetrain losses. These comparisons are essentially meaningless. Inertial dynos are based on the sound scientific priciple of accelerating a certain mass with a known moment(distance) over a given time. The rate of acceleration of that mass and moment is a result of the force applied (torque). If the RPM is known, HP can be calculated. On an inertial chassis dyno, it is virtually impossible to calculate the the moment of inertia of every tire, wheel, gear, joint , axle and shaft in the power train between the crankshaft and roller, therefore its results cannot offer an accurate HP figure. Even with coastdown drag measurements, these cannot be accurately calculated as different factors are affected in different ways. Some are proportional, some are inverse squared functions etc. Inertial engine dynos offer a very accurate figure if properly calibrated as only the flywheel's moment of inertia needs to be calculated and added to that of the billet. Water brake or eddy current dynos generally measure force (torque) directly through a ram or strain gauge so moments of inertia are not important on these in fully loaded tests.
Concluding that there was a 25% drivetrain loss by comparing HP achieved on an inertial chassis dyno and that obtained on an engine dyno is fundamentally flawed in that the chassis dyno numbers are highly suspect in the first place.
Other things to watch are correction factors applied for altitude, barometric pressure and temperature. These factors are NOT the same for atmo and turbo engines. Using atmo factors inflates the true, corrected HP figures on a turbo engine. In fact, look at the correction factor applied on your dyno sheets and see if they make sense. Many shady dyno operators simply enter a phantom correction factor to make the customer happy. This is a case where the dyno sheet DOES lie. Chassis dynos are essentially for tuning purposes, they are not well suited to giving an accurate hp figure.
Be aware that SAE correction factors do not apply to turbocharged engines! If your dyno sheet lists SAE corrected HP, ignore it as it is incorrect. You are better off getting an idea of where you stand by looking at observed hp with a turbo engine.
04/28/02
One of my friends recently received a well known commercially available chassis dyno with both inertial and eddy current loading capability. When a different vehicle weight is entered in the software for a pull, the computer spits out a dyno sheet with vastly different hp figures. This is complete BS and shows that the software package is just plain wrong. HP did NOT change on the pull simply because a different weight was plugged into the computer. Take all these figures with a grain of salt. I had an engineer from this company E-mail me and tell me their dynos were accurate. I told him I'd be happy to look at his data and asked him to send me his information to support this claim. I never heard back. Changing the weight DOES NOT change the hp the engine puts out PERIOD!
Another SDS customer had his drag car chassis dynoed. It showed a max hp of 280 yet when the car weight, ET and trap speed were plugged in, these showed that around 500hp was required to achieve these results. The dyno figure was so far off, it was essentially useless.
10/31/02
Looking at the jagged, sawtooth "curve" that most chassis dynos produce is amusing. The torque and hp curves really don't look like this. This is a result of poor software or mechanical measurement in the first place. Torque does not go up down, up down 2-4 ft./lbs. over 50-100 rpm as any real engine dyno will prove. Chassis dynos are essentially tuning aids, not true hp measurement devices. Use them to dial in your EMS mapping, not to brag to your friend's that you made XXX hp. When he blows you away at the stoplight, you'll just look, just, well, uninformed.
For you doubters out there, here is some more food for thought:
Stahl Headers Dynos
sportcompact dynos
dynos don't lie
Puma Race Engines Technical Guide - Measuring Engine power - engine dynos and rolling road dynos
Puma Race Engines Technical Guide - Coastdown Losses as measured on Rolling Road dynos
Thank you but perhaps I did not make myself clear. Car engines today are rated with a water pump etc. as above. Surely that is a bigger deal than rear wheel hp vs flywheel hp.
The new HP ratings are at the flywheel, also.
HP rating in the 60's had no std of measurement, so if someone wanted to test a motor in the dead of winter with open headers and no accessory belts hooked up, nobody stopped them.
This is where 225 HP 2bbl 289's came from. the same engine in today's HP rating would have been lucky to make 140 HP.
Its been 45 years but I seem to recall a 1965 389 2 bbl with automatic which jumped it to a premium gas car to 290 hp. Had a 2.29 rear end unless I have my years mixed too. Yeah, quite slow. I took a 1963 two bbl with 4 speed out and it was a real dog. We must remember that is was likely made in 1962 when the Mobil Gas Economy Run was a big thing.
I'm no expert, but I'd swear that I read that HP ratings in the old days were done without accessories on the engine, versus today. In other words, no alternator, A/C, water pump, etc. drag on the engine.
I recall that back in the olds days... to keep insurance costs down, car companies under rated HP. Example a 1970 Buick Electra 455... as mild and docile engine for a luxury car... was rated at 370HP but a Stage 1 455 in a GS... which had a bigger cam, better heads with bigger valves, etc... was only rated at 360 HP:rolleyes:
Today, in contrast, I think many car companies vastly exaggerate HP in an effort to sell more cars.
I read that too but hey, it was 45 years ago.
A suggested car was
1983 Regal Wagon with a bonus!
Have a 1983 Regal wagon daily driver for sale. Car has new paint (Maaco), new front seat upholstery, new headliner, complete set of 15" Buick ralleys and center caps. Odometer reads 85K, probably turned over once. This car was rescued from previous owner who neglected it for several year leaving it out in the weather.
Here's the bonus, it has an '87 Mr Goodwrench dealer replacement V6, 109 block. I bought it a little over a year ago with the idea of converting it to a turbo car but with all my other projects.....well, you know how it goes.
The car runs and drives fine and is very reliable. I did all the body prep before taking it to Maaco but must admit I missed several parking lot dings, looks great though from 10 ft. Body is solid, no rust, good glass, doors and tail gate shut fine.
I have always liked wagons and this one is no exception. They are much rarer than the Chevy Malibu or Olds Cutlass as Buick only made them in '82 and '83. I live in the Northwest so this car would probably not be worth shipping cross country unless someone is really hot for it. I still think it would be a good candidate for a hibrid or just a driver if that's all you want.
What is a 109 block and if its a special version of the 3.8 how hard is it to turbo it?
They also usually didn't use the factory exhaust, either, but since everybody had there own standard of measurement the numbers are pretty meaningless.
There were motors that had "underrated" HP numbers, either for insurance reasons or marketing or because of corporate edicts, but most of those "underated numbers would still be lower if measured in modern SAE std. net HP of today.
Ssg Ken;2185487)What is a 109 block and if its a special version of the 3.8 how hard is it to turbo it?[/QUOTE said:
The 109 block is what was used in the 86-87 and TTA Pontiacs. There are several changes you need to do and it aint cheap. If you want a cheap upgrade you can swap in a 4.1L 4bbl intake and add 25-35 ponies with the same gas mileage and if you add a slightly bigger cam you can easily add 50 hp. The car looks good BTW so if the wife is in to it I say go for it.
As was stated today's HP is SAE net and the old HP numbers were SAE gross HP. The net HP has all accessories and exhaust compared to gross HP with no parasitic load and open intake and exhaust.
Thanks,
Mike
