I don't know if these pics will help anybody, to see if I did a good job or not as far as hole porting is concerned. Anyway I just put everything back together and ran a hose directly from actuator to compressor, instead of all the hose I had previously had, trying to hide RJC valve. Thinking maybe the length of the hoses was causing me my boost problems. So I took my car around the block and it is still at 23 lbs and climbing slowly at WOT, and this is with standard actuator. My waste gate rod is 1 turn in from just slipping right on puck arm.
Any and all help is appreciated.
