I had a heavy duty actuator first and couldn't go more than 3/4 throttle, having 25 lbs of boost and climbing with more throttle given. I did pull the actuator arm off the puck and got no boost. So I did get a new standard duty actuator, put it on, ran hose from turbo to actuator adjusted rod to half turn in, from just slipping on puck arm. Now my turbo isn't spooling up fast and once it does get spooled up, it kind of sets in at 17/18 lbs and slowly climbs from there. Before I ever mounted new turbo, I ported hole to where it had 1/8th inch all the way around for puck to seat on. I've tried everything that I know to do, still with no luck.
