SignUp Now!I can believe it.
Especially with the amount of airflow this new Billet 67 compressor wheel has combined with the flow of the HPQ turbine wheel.
Patrick
I didn't say they didn't work across the board.... let me clarify.....I said there are several people that have found after swapping to these new billet wheel turbos.... 62mm and 67mm...... that they found they now have major boost control issues.... lots of boost creep......where they didn't have any before the swap....... do a search Grumpy..... :wink:
Patrick,
What injectors would you recommend with this turbo on a 231 inch motor?
........snip......
I can buy the 10 sec run but not the 18psi - maybe more like 21 or so. My street car went 10.80 at 21# and a soft 60ft time with a 6765.
Yea.... but you weren't running stock heads..... and stock cam..... and stock intake...... etc..... that is where I am (as well as several others) are questioning the actual boost it took to run that time at that weight..... with an otherwise stock motor......
Will was also not running the 68/HPQ Turbine wheel, which is rumored to make
huge power differences over the smaller wheel. Not apples to apples for sure.
I say send the turbo to will and let him make some passes!!!
The HPQ wheel is only "rated - and I use that term loosely" at 55 HP more than the 65 wheel. He doesn't mention what housing he's using. I don't think there's much more to be had with the HPQ wheel on a stock cube motor anyway - JMO.
My next "street" engine will have a billet 71 at the minimum - winter is starting to set in!:biggrin:
OMG, what are you doing now???!!!
I agree Will....... the stock heads are a coffee stirring straw you are trying to blow thru.....the size of the air compressor you put on one end at low boost (18 psi) isn't going to make a hundred hp difference at that boost level..... that's all.
Ported GN1's..... 18 psi..... high 10's are quite possible IMHO.....with one of these bad boy turbos.....
This turbo has the H cover..... Who knows I might be lying abt that too!
Here is the video
YouTube - tta299's Channel
Here is the video
Please don't take offense to anything I've said Scott. I don't doubt that you ran the time and I'm sure your gauge did say 18#. I was refering to the aspect ratio (A/R) of your exhaust housing.
I do have to agree with Bison that with no data to validate, it simply defys the laws of physics here as far as the car weight, CID, airflow potential, etc. Regardless - you ran the number with a stock longblock which was your goal. I would just advise you to get that gauge as well as the vac/boost source and lines checked before you drop another slug in it. Good luck!
I hope I am not a bad person...
Anyway are you lying if what you saying you believe to be true?
Here is the video
