Got this the other day and it rocks...6x9 fit perfectly to this mount and the mount fits to the 4x10 hole...no cutting no poblems....
http://www.ebay.com/itm/230967380948?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
It's easy to put 6X9's in the back deck without adapters. remove the back seat, remove the back deck cover....
then snip the little piece bisecting the oval hole close to the back glass. Then make two vertical cuts about 6" apart that allow the 6X9 to sit flush with the back deck (make sure to leave metal where the mounting holes are). Shoot drywall screws up from the bottom then break them off flush with the deck (they're hardened so they'll snap clean). Reinstall the deck and back seat. It will look bone stock from the inside and sound better than those plastic adapters.....
.....assuming you can take a pair of snips to your car![]()
My memory much be fading... I was thinking the rockin' system was pioneers 690XX 3-ways (giggity) on the back deck with a 'supertuner III"![]()
That sounds familiar.My memory much be fading... I was thinking the rockin' system was pioneers 690XX 3-ways (giggity) on the back deck with a 'supertuner III"![]()
