Are you going to run nitrous? If not, (or even with a small shot) no matter what you do to a N/A 3.8L you will not break the 7.5. With only 231 cubic inches there is only so much power that can be made. I would say that 350 ft/lbs is the very top end and probably very optomistic. I have run a slightly modified N/A 4.1L with a 4speed and a 7.5 rear and it was fine. I hated the clutch wear problem and added pressure plate only added to the problems. Engine thrust bearing longevity is not good with a manual trans but I digress. Weld the tubes to the center section, get a rear end girdle, and for about 200 bucks it will live a really long life. The only reason I am even considering changing mine is because the 7.5 is a C-clip axle and I am pretty sure with the new engine the car will be fast enough to require retainers. Once we get to that level, the upgrade cost does factor in. Yes my car is several hundred pounds lighter than a Regal but with a wheels up trans-brake launch it is still hitting the rear end plenty hard. IMO at your level an 8.5 is cool but a big waste of money.
