I need a file for these injectors.  Presuming the low-Z injectors are different enough from the high-Zs, I tried making one from a 55 file, but it didn't work well at all (missing, popping).  I checked gnttype.org, but not much available at the moment.
Suggestions??
			Suggestions??
 .  If you have a dyno test and have drivers like ours that like the "digital mode - stomp and lift, stomp and lift", then cut the boost and don't let it go into pe mode.  Set all the pe entry thresholds to the max, and zero all the wastegate duty cycle vs rpm entries, and you are pretty much done.  It's fine to drive this on the street so long as you don't make more than maybe 5 psi boost.  Hm, I just looked at gnttype and don't see the technical articles?  If you have any actual stock chips, either the acxa or bbkj, just start with that.
