My phone number is 585-394-7881 after 3pm
Here is a video of the car with normal aspirated carb, now has D-SC1 and Pro Carb on:
YouTube - 1967 Vega, 385, Suprecharged
For Sale is My Four year project, my 1976 Chevy Vega. It came from Ohio and has only 18,000 original miles on it. Included with the car is the original engine and air cooled automatic transmission. This car has NO RUST!! It has a 5 lug front wheels in a chevy pattern with disc brakes and a five lug ford pattrern in the rear with drums. The one thing I would possibly change is to install air bags instead of the air shock on it now. I built this car because Im an old fan of Grumpy Jenkins. The roll bar was installed as to make it simple to remove if wanted. Below is a list of most of what was done to the car. I did not want the typical tubbed Vega, I wanted to be able to take my kids for a ride in the back seat, therefore, no tubbing. Should be a 10 second car easily with exhaust on. Pistons are -26cc mahle with deep ring lands. compression ratio below 9:1. Some of the plastic interior parts are the were remade from aliminum or steel, such as the seat belt guides and the visor pivots. The supercharger was just replaced on the motor an Edlebrock Air Gap Intake manifold and a large breather piped to take in cold air from the front of the grill., new pistons and rings, . The 5 way Harness is out of date, but like new. It never fails, Ill work on something till its near perfect and sell it, this car is no exception.
Engine:
355 ZZ-4 block bored to 4.040 and stroked to 3.75 inches
H- Clevite bearings
Eagle 4340 Crank Shaft
Eagle I Beam rods
Mahle -26cc Pistons
Melling Hi volume oil pump
Marroso Deep sump Oil Pan With Swing Gate
Sumped Gas Tank (sump kit)
Aeromotive A1000 Fuel Pump
Aeromotive Fuel Pump Controller
1/2 inch Braided Fuel line and 3/8 Return line and fittings
Aeromotive Fuel Presser Regulator
Dual braided 8n Float Bowl Feeds (& fittings)
750 pro built blow through carb ($1200.) with annular boosters
MSD Boost Controlled Timming Master and MSD Coil
MSD Distributor
Edlebrock Single Plane Aluminum Manifold
HD Aluminum 4 core Radiator
Aluminum Dart-Pro Heads 205\160 valves 215 runners and 64cc chambers, 3 angle V
roller rockers
Double Rolling Timing Chain w/thust button and bearing
Chrome Molly Pushrods
Lunati roller lifters (solid)
Comp Cam X-streem CAM #12-704-8 _ 114 lobe center 5.56 lift
Remote oil filter
Hooker big tube headers
2.5 inch exaust with flowmaster mufflers
Light weight GM Weight Starter
3800 stall TCI Torque Converter
Race prepped T-400 by Abruzzi Racing, good for 2000 hp
Hurst Ratchet shifter
All new HD universals and shaft
Pro- Charger D-1SC Supercharger
Extreem Pro Carb Hat
Tiah Blow off Valve
7300
Snow Methanol Injection System
Boost Gage
A\F Guage
Innovative Motor Sports Engine Monitoring System
Total engine parts
Had new pistons -26 cc Mahles, new, all new H series bearings put in, also new eagle 5.7 rods. 9/1/10. drove for 8 mile 9/4/10
Rear:
Ford 9 inch with brand new Mosier Axles
3.22 gears
Detroit Locker Posi Unit
Brand new 11.5 inch Drum and Brake Shoes
Disk Front brakes
5 Lug Front wheels
All new Brake lines
Pan Hard Rear Stabillizer Bar
Ladder Bar Suspension
Coil overs with Air Shocks
Frame:
2 X 2 Sub Frame
Drive Shaft Loop
Roll Cage
Safety Harness
Body:
Only 18,000 original miles
New carpet
Not Tubbed (as all the rest are)
Tilt steering wheel
remote mirror
NO RUST
Full Rear Seat
Original Engine and Transmission come with the car (with only 18000 miles on them)
Hood scoop is a 1969 Corvette Stingray Style
Drag Star Wheels and Drag Radials
Conclusion, This is one of the finest Chevy Vega's you will find and you will not find one more RUST FREE. The drive train is bullet proof.
Will trade for 67-69 camaro. 1987 buick or 1989 TTA firebird + cash
Engine:
H- Clevite bearings
Eagle I Beam rods
Mahle -26cc Pistons
MSD Distributor
roller rockers
Remote oil filter
Tiah Blow off Valve
7300
Boost Gage
A\F Guage
Total engine parts
Rear:
3.22 gears
Disk Front brakes
5 Lug Front wheels
All new Brake lines
Frame:
2 X 2 Sub Frame
Drive Shaft Loop
Roll Cage
Safety Harness
Body:
New carpet
Tilt steering wheel
remote mirror
NO RUST
Full Rear Seat
