The breather line to the air cleaner is part of the PCV system, so I would start by changing the PCV valve. It's not easy as it's on the intake manifold, just under the plenum (between the carb and turbo).
If it's running poorly, the oil may be symptom, not a cause. Check the vacuum lines and the thigs they are connected to for leaks. Make sure the boost/vacuum lines from the turbo compressor to a wastegate actuator are good and solid.
What part caught on fire?
