sleeper buick
- May 2, 2006
ok i have a 7th inj on my car and was trying to deside to stay with it( cause it works fine) or move on to alky. any advice?
SignUp Now!Why not Both!!:biggrin: The alky is to supress detonation. The 7th is to keep from buying larger injectors. I know some are going to say the alky is a fuel and dump the 7th. I say if the car runs fine with the current setup and you just want more boost on pump gas Alky is the hot ticket. Look how many just add Alky without upgrading injectors at the same time...![]()
One problem with running a 7th injector with alky is it would be harder to tune with the fuel provided with the chip plus the fuel from the 7th injector plus the fuel from the alky. I bet if you asked any alky chip maker they would say dump the 7th. You might be able to get by with removing the 7th inj and replacing it with an alky unit. What is you setup?
David
87GN
The 7th injector was a band-aid to keep the back 2 cyls from running lean...now that we have bigger injectors...power plate...etc available it's no longer needed...old technology...get rid of it...JMO...
+1
Just one more piece that if it doesn't function.... bye bye engine or bye bye head gaskets.
definately a band aid for too small on the injectors...
Get a Razor's alky kit.... and a TurboTweak chip.....
That will make more power for less $$ than ANYTHING else you can put on your car period....
You will love it...
yeah i was looking at both, and i need to get my hands on a prologger and scanmaster
