SignUp Now!It's about 1in shorter on each side. Control arms should bolt up.
I put in a Olds 8.2 in my 85 cutlass.. there was just enough flex in the LCA's to get them into the stock mounting points. You'll have to flex yours in.
How did it work suspension travel? Any binding?
I let go a GN rear because of the thread I posted a link to.
I guess I should have talked to the PROS over here first.
I hate it when ship like this happens.
And now I will have to get a “WTB GOOD USED GN POSI REAR” thread going as soon as the money is available:frown:
I'll keep you in mind... I may have just launched my motor this morning.. if so, I don't have the money to rebuild it, and probably won't for quite some time.
So it'll be parted out if I become a member of the DOTC club today
I'm hoping for somthing electrical, or a broken flywheel... but who knows.
The 71-72 Buick 8.5s can still be had very reasonably priced. Put up a wanted post on v8buick.com and you'll find one. The 71-72 Buick rear is a direct bolt in for your chevelle, plus it has bolt-in axles from the factory so no c-clip eliminators are required. A GN posi unit and gears bolt right in the housing. You can use a driveshaft from the 71-72 Buick with TH350 for a completely bolt in swap with no other mods required.
