turboc87gn
Darkside in Detroit
- Oct 2, 2008
Id like to see the numbers with a with a double pumper....
SignUp Now!Any idea how many amps a walbro 340 can pull?
Maximum of 14 amps by itself, maximum of 9 amps in-series feeding a downstream pump.
You should upgrade the pump first and see whats possible before changing to the 120s...I dunno about anyone else but my eyes will be glued to the screen lol...
How many LPH will the Bosch 044 do? There's a modified denso that will do 300 LPH.
Is this chart way off base then?
B MOTORSPORT COMPONENTS
FUEL PUMP TECHNICAL DATA
Part Number........ litres / hour ......(pressure)
0 580 254 023........... 168............ (5 Bar) (72psi)
0 580 254 040........... 102............ (6.5 Bar) (94psi)
0 580 254 044........... 200 ............(5 Bar) (72psi)
0 580 254 046........... 207............ (3 Bar) (43psi)
0 580 254 053........... 175............ (5 Bar) (72psi)
0 580 254 909........... 148............ (5 Bar) (72psi)
0 580 254 910........... 130............ (5 Bar) (72psi)
0 580 254 911........... 95.............. (4 Bar) (58psi)
0 580 254 975........... 165............ (5 Bar) (72psi)
0 580 254 979........... 165............ (5 Bar) (72psi)
0 580 254 984........... 165............ (5 Bar) (72psi)
0 580 464 069........... 98.............. (4 Bar) (58psi)
0 580 464 070........... 130............ (3 Bar) (43psi)
B 261 205 413.......... 200............ (8 Bar) (116psi)
Bosch and Lucas Fuel pumps
